flex 500 emailing myself notifications using Microsoft 365
Hello,it works for me.on 365 You have to first enable smtp with authentification in Your account.on the FLEX or USGsmtp.office365.comport: 587TLS and STARTLS checked do not check authenticated servercheck smtp authntication and fill user and password.0
I dont want to / cant use authentication as all our accounts have 2FA enabled.
I simply want to send a mail from my own address to my own address without authentication - i use the same method for our scanners here in the office and they work fine - just cant get this firewall to do the same
Which settings are you using from your scanners? Did you apply the same to the firewall?RoyCruse said:I simply want to send a mail from my own address to my own address without authentication - i use the same method for our scanners here in the office and they work fine
Maybe emails or user agents are managed differently, and Microsoft (not you) decide what to allow access and what not...1 -
Hi @RoyCruse,
Can you post error log in "MONITOR > Log > View Log"?
It should have fail reason when device send notification mail fail.
Hi, I dont get an error which would be really useful...
Instead I get an info line saying my address is not accepted by the server.
The addresses are 100% correct
I have checked and double checked mail server details and tried multiple different sender and recipients including exactly the same setup as our scanner
Ive also tried with and without TLS/StartTLS (as this is specified as optional in the m365 instructions here)
heres my mail server config
We have a connector setup in M365 allowing mail from our entire ip range, ive also added our ip range to our spf record as this helped stop mails from the scanner going to spam
I run a message trace from M365 and there's no entries for the mail from the firewall at all so cannot get any errors from that side.
As i said our scanners can scan and email using the exact same settings and have done for years...0 -
Ok so i eventually ran a packet capture and it would appear the external ip used by the firewall is blacklisted with M365 and was returning the following error550 5.7.606 Access denied, banned sending IP [xxx.xxx.xxx.xxx]. To request removal from this list please visit https://sender.office.com/ and follow the directions. For more information please go to http://go.microsoft.com/fwlink/?LinkID=526655So it would seem theres a bug in the logging on the firewall as the issue is being reported in the logs as "recipient address not accepted by the server"
If only you had displayed the error code that you were returned by the mail server as is:- 550 5.7.606 - i would have known the exact problem right from the get go.
perhapse an update for the next firmware release. ?1 -
Thanks for digging into.
Thanks for valuable feedback.
We will evaluate if it is doable in gateway to parse return message in system log.0
- 588 USG FLEX H Series
- 477 News and Release
