High cpu usage on USG40w
IT_Field_Support
in Security
We have an issue on one of our router.
CPU is always 99%.
I check the settings, tried to disable CF, Secureporter, logging etc.. without founding the cause of the high cpu usage.
In console i can see that this process is always high :
31006 31001 python root ? 19 0 51.0 0.5 R 11856 5712 3432 2964 09:59:43 00:03 00:00:01 python /usr/sbin/reg_agent.pyc 1 16b37c4cc5a135c075ede86977a6052daf436608c3aee5e788b2ff80 4.70(AALB.0)
Router is really slow.
Thanks for support
Any IPSec VPN active?
USG40 with ... 6mbyte/s of SMB transfer on VPN (Ikev2, AES256) have CPU Stuck around 92-99%0 -
The process /usr/sbin/reg_agent.py shoule be done in short time.Can you provide device web gui access in PM. We would like to check this device status.1
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
