How to restore my Zywall 110
Jarno_Smits
Jarno_Smits Posts: 23 image  Freshman Member
Good morning,
I got a Zywall 110 with old firmware, it was running on verion 4.15 on paritition 2
and in the standby paritition 1  was version 4.10.
My bad i didn't read the warning notes, and I upgraded in the UI the zywall  to 4.71...
I uploaded version 4.71 into paritition 1 and rebooted the zywall
Now the Zywall dont startup anymore, the sysled stays blinking.
I was posible  with the serial interface to got the zywall working again by using the "atcd 2" command that it startup again with release 4.10 from paritition 2
because i later know that i needed to use firmware 4.20 first to upgrade into steps to 4.71 , i uploaded now version 4.20 into paritition 2 ( with 4.15 ) and i rebooted the zywall.
But now the zywall is also stuck with a blinking sysled, and also with the serial cable it isn't posible anymore to switch the parititions, i get strange error messages when i want to boot now from paritition 1 or 2 , see the logs below:
BootModule Version: V1.08 | 08/15/2013 10:45:46
DRAM: Size = 1024 Mbytes
Press any key to enter debug mode within 3 seconds.
Enter Debug Mode
ZyWALL 110> atcd 1
Change Boot Number=1
ZyWALL 110> atgod
Booting...
mount: wrong fs type, bad option, bad superblock on /dev/sda4,
       missing codepage or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
Error trying to mount db partition 5 times
       dmesg | tail  or so
Could not write 8 blocks in inode table starting at 81923: Attempt to write block from filesystem resulted in short write
mount: wrong fs type, bad option, bad superblock on /dev/sda6,
       dmesg | tail  or so
       dmesg | tail  or so
mount: wrong fs type, bad option, bad superblock on /dev/sda3,
       dmesg | tail  or so
Connect a computer to port 1 and FTP to 192.168.1.1 to upload the new file.
And when i want to boot from Paritition 2 where version 4.20 is in now:
EHCI timed out on TD - token=0x800d8d80, td=c00cc7a0, timeout=5000, pipe=0xc8008383
EHCI timed out on TD - token=0x80008d80, td=c00cc7e0, timeout=1000, pipe=0x88000303
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
       dmesg | tail  or so
I also tried to upload with FTP new firmware into the zywall , but when uploading with FTP, i got a message that the transfer is succeded, in the FTP console, but on the serial console i got a message that the firmware format isn't correct.
( i used the bin command in the FTP program to change to the correct format )
for the info, the version 4.20 i used is: 420AAAA2C0.bin
and the release 4.71 i used first is release: 471AAAA0C0.bin
im out of options now, can someone help me to restore the zywall 110 or is it bricked?
kind regards,
Jarno Smits
    PeterUK Posts: 4,411 image  Guru Member
    hold the reset in for 20 seconds as its on  4.71 firmware should work
  • osake_li_09
    osake_li_09 Posts: 9 image  Freshman Member
    When you upload firmware .bin file via FTP, did you disable the Windows defender firewall or another firewall software? You may disable it and try again.
  • Jarno_Smits
    good morning,
    i tried already the 20 second reset procedure, but without any success..
    Also i disabled the firewall from the pc, one time i got the message that the file transfer with version 4.20 is succeeded, but after the reboot i still get the same messages, after every reboot:
           dmesg | tail  or so
    I also tried to boot from a different image with the atcd 0 atcd 1 and atcd 2 command, but still the same.
    Only thing i can try is to upload a older version back example version 4.10 of 4.15, but i can't find these on the download page, can someone send me these files?
    Or does someone have a other step by step guide, maybe i'm exacuting wrong steps?
    Kind regards,
    Jarno
    I have uploaded "ZyWALL 110_4.10(AAAA.0)C0.zip" here:
    https://ufile.io/js1dx7zt
  • Jarno_Smits
    Hello Peter,
    Thank you for the 4.10 firmware, i tried to upload it into the zywall, but still after the reboot i got the same error messages.
    I'm not sure what is the right procedure now.
    The steps i did to upload the firmware:
    - first i selected a image with command atcd 1 ( for image 1)
    - rebooted the device with command atog
    - when it startup again i enterd the debug mode.
    - then i used the comand atkz -f -l 192.168.1.1
    - rebooted with atgof
    then i opened with cmd  the ftp from windows:
    used the command "bin " and "hash and then uploaded the bin file with the firmware.
    ( I get the info that the file is transferd , but when i checked the console screen still i get the message that the format of the firmware is wrong and that i need to that that it is binary ?
    Can someone help me with the exact procedure?  or are the steps correct what i did?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    According to "mount: wrong fs type, bad option, bad superblock", it could be database has been damaged, please try db recovery.
    The steps are the same as uploading .bin file via FTP, except uploading the .db file. (471AAAA0C0.db)
    Thank you.
    James.
  • Jarno_Smits
    hello James,
    Sorry for the delayed answer, i also tried to upload the .db file in the simalair way, but still no success, almost every time i get the message that if a file is uploaded that the format is wrong??
    that it must be binary??
    I'm using the ftp function from Windows 11 in the command prompt, as descriped in the zyxel troubleshoot notes i found online, before uploading in need to use the command bin, and hash.
    I also tried to use filezilla to access the paritition of the zywall, i'm able to access the paritition, but when i tried to upload the firmware file or a db file, then the upload dont start.
    Does someone have some experiance with other FTP tools to upload the files to the zywall?
    that i can try, otherwise i think this zywall is good for the ewaste.
  • Zyxel_James
    Yes, the command "bin" is necessary.
    Which troubleshoot notes did you refer to?
    database recovery has another step that firmware recovery doesn't have, that is, input "atcd 1" after entering to the debug mode, is it possible you miss this step?
    Please disable the PC firewall and refer to the steps below.
    If db recovery still fail, could you provide the entire FTP log and console log? Thank you.
    James
    1. Initial database recover process.
    Connect the device directly via the console port using a terminal emulation program. And also connect the device on 1st Ethernet port with your PC. Reboot the device.
    • Enter to debug mode
    • Enter "atcd 1"
    • Enter "atkz -f -l 192.168.1.1"
    • Enter "atgof"
    • After entering "atgof" system will go to restart and initial FTP server on device.
    2. Upload Database file to device
    • Change your PC IP address as 192.168.1.1.2 and mask 255.255.255.0
    • Access device by FTP(by anonymous) and upload XXXX.db file.
    • System will start to recover as default database.
    After finishing the steps, you can do power recycle to make sure your device could boot up successfully.
  • Jarno_Smits
    James
    • Enter "atcd 1"
    • Enter "atgof"
    Hello James,
    I tried this procedure already, i did it again exactly as you descriped, see below the messages i get from the Zywall:
    ZyWALL 110> atcd 1
    ZyWALL 110> atkz -f -l 192.168.1.1
    -f -l 192.168.1.1
    OK
    ZyWALL 110> atgof
    Booting...
           dmesg | tail  or so
           dmesg | tail  or so
           dmesg | tail  or so
           dmesg | tail  or so
    below the screenshot from the console when i upload the db file with FTP:
  • Zyxel_James
    Hello @Jarno_Smits
    Is it possible to arrange a remote session for database recovery?
    I will contact you through private message, please check on your inbox, thank you.
    James
