Rancid or oxidized support for USG
An interesting tools.
I just test rancid and works for the first part of clogin.
It can auto login to USG and run CLI commands in a script file.# clogin -f .cloginrc -x myscriptfile.txt 192.168.1.1With cron job then I can schedule an automatic configuration change task.
About the configuration backup and differ part.
It need to modify the "rancid" Perl script to support zyxel USG device.
That's a little bit above me that didn't learn Perl script.
@tsch
Here comes the modified rancid script I test with rancid 2.3.8 on my raspberry pi3.
Replace "rancid-fe" and add "zldrancid" into /var/lib/rancid/bin directory.
Enjoy !
Note:
I just test with the basic configuration backup to CVS repository.
The filter function of password, snmp,etc. might not work.
Rancid 2.3.8 is very old. Do you have a newer Version of it. Also Oxidized would be very interesting.
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
