All devices can ping only itself and the router (lan)
The Router is zyxel EMG1702-T10A.
When i try to ping any devices in my lan network, i get this output :
ping 192.168.1.104 PING 192.168.1.104 (192.168.1.104) 56(84) bytes of data. From 192.168.1.108 icmp_seq=1 Destination Host Unreachable From 192.168.1.108 icmp_seq=2 Destination Host Unreachable From 192.168.1.108 icmp_seq=3 Destination Host Unreachable From 192.168.1.108 icmp_seq=4 Destination Host Unreachable From 192.168.1.108 icmp_seq=5 Destination Host Unreachable From 192.168.1.108 icmp_seq=6 Destination Host Unreachable
The ping only suceed when pingin itself and the router :
itself -
ping 192.168.1.108 PING 192.168.1.108 (192.168.1.108) 56(84) bytes of data. 64 bytes from 192.168.1.108: icmp_seq=1 ttl=64 time=0.029 ms 64 bytes from 192.168.1.108: icmp_seq=2 ttl=64 time=0.042 ms 64 bytes from 192.168.1.108: icmp_seq=3 ttl=64 time=0.065 ms 64 bytes from 192.168.1.108: icmp_seq=4 ttl=64 time=0.063 ms
the router -
ping 192.168.1.1 PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data. 64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.92 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=3.17 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.05 ms 64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=1.38 ms
Tested with 3 devices, 2 linux and 1 android, and got the same output. ALl of them connected to the router via wifi. All host were up.
Output of some troubleshooting :
i tried
<code>sudo ip route add 192.168.1.104/32 via 192.168.1.1 dev wlan0and
<code>sudo ip route add 192.168.1.104 via 192.168.1.1 dev wlan0but this is the output :
ping 192.168.1.104 PING 192.168.1.104 (192.168.1.104) 56(84) bytes of data. From 192.168.1.1: icmp_seq=2 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=3 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=4 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=5 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=6 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=8 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=11 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.1: icmp_seq=17 Redirect Host(New nexthop: 192.168.1.104) From 192.168.1.108 icmp_seq=26 Destination Host Unreachable From 192.168.1.108 icmp_seq=27 Destination Host Unreachable From 192.168.1.108 icmp_seq=28 Destination Host Unreachable From 192.168.1.108 icmp_seq=29 Destination Host Unreachable From 192.168.1.108 icmp_seq=30 Destination Host Unreachable From 192.168.1.108 icmp_seq=31 Destination Host Unreachable From 192.168.1.108 icmp_seq=32 Destination Host Unreachable
I did try some other solutions, since its a common issue, but as none of them worked, i decided make another question about it.
I was suggested to activate icmp on acl, but it didnt worked.I dont know if i did it right tho. I tried using the source ip addres and source mask addres, respectivly : 0.0.0.0, 0.0.0.0. And then : 192.168.1.0 , 255.255.255.0
I was also suggested to turn off an possible option that determines that the devices will only talk to the internet, but never with eachother. Bu i dont know what that option would look like, and didnt find it.
Issue solved. Thanks.0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
