UAG 5100 how to allowed some device AP access internet without authentication in LAN1 hotspot?
Hello @greg,
You could create a new policy for the access point to bypass the web authentication.
First, navigate to configure > Network > IP/MAC binding, add a static DHCP binding profile for the access point in the LAN1 network.
Secondly, navigate to Configure > Object > Address, and create an address object that binding to the access point.
Finally, create a web authentication policy for the access point to bypass the web auth, select the object AccessPoint as the Source Address, and select “unnecessary” as the authentication.
With the above settings, the WiFi clients on LAN1 network need to pass the web authentication for the internet access, however, the access point does not.
Thanks!
James.
Hello @greg,
Thanks!
James.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
