Chromecast not work on IPSEC VPN beetwen two USG210
Hello @Manuel13
The Chromecast mirror function could only work in the same IP subnet.
If you would like to transmit "Bonjour" "SSDP" multicast protocol from another subnet, the device must support multicast cross subnet routing. However, currently Zywall only supports IGMP proxy.
Thanks!
James.
Asking google to allow stream from another subnet?0
Hello @Manuel13
Thanks!
James.
Zyxel_James said:Hello @Manuel13James.
Thanks!
Thanks James... How product Zyxel is compatible with "Bonjour" "SSDP" multicast?0 -
Hi @Manuel13,Do you mean which Zyxel product is compatible with "Bonjour" "SSDP" multicast?Currently, Zyxel Firewalls support IGMP Proxy over VPN tunnel.Bonjour service only works when client and server are in the same IP broadcast subnet. This kind of multicast doesn’t support in current VPN scenario on Zyxel Firewalls.Thank you.James.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
