Does ZTE MF79U support Zyxel USG20W-VPN
arthurkk
arthurkk Posts: 10 image  Freshman Member
I am using the USG20W-VPN. Does the ZTE MF79U SIM dongle support it? Not easy find ZTE MF823 / MF833 or Huawei E3372 in the market. Tks.
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
  • arthurkk
    Yes I have downloaded this before. The list is out date. Last update is on 2019. However, I have tried a Huawei E55xx on USG20-VPN's USB port. It works however the download speed is around 4.5Mbps (my plan is 4G - 45Mbps). I saw it used the profile 1 , I cannot find where to change the Profile on cellular page. I think it should have around 21 profiles right?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 975 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @arthurkk,
    Welcome to Forum ,
    Dongle is mainly carry out on a project basis now, Because the Dongle has country restrictions.If there is no project request to cooperate with the customer, we can't conduct the test.
    We suggest you could use the device with SIM card and LAN Port. Then connect the LAN to firewall's wan.
    Keivn
  • arthurkk
    Thank you so much
