Locked out of my own USG110
Hi @WebWorks,
The fix is already included in the latest firmware version 4.35.
You can find the bug fix on page 30 of the release note.
If you meet the issue because the password is expired, you have to follow the FAQ to recover the configuration and set a new password.Then upgrade to the new date firmware to avoid the password issue in the future.
If you don't have the issue right now because the password is not expired, upgrade to the latest firmware 4.35 to avoid the issue.
I've just had this same issue with a password reset starting with '
Is restoring from a backup the only option here?0 -
Should say I downloaded startup-config.conf before the update, is that the correct file to restore?0
If I don't have a backup, is there any way to get in and reset the password? This forced password change really messed me up. Is it worth it to make us do this and lock us out? My router was running fine. Now it is almost a brick.0
You can refer to this thread to backup configuration if you lost your password.
And send out your configuration by new firmware.
https://community.zyxel.com/en/discussion/comment/35202#Comment_35202
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 920 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
