Locked out of my own USG110
2»
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,427  Zyxel Employee
    Hi @WebWorks,
    The fix is already included in the latest firmware version 4.35.
    You can find the bug fix on page 30 of the release note.
    If you meet the issue because the password is expired, you have to follow the FAQ to recover the configuration and set a new password.Then upgrade to the new date firmware to avoid the password issue in the future.
    If you don't have the issue right now because the password is not expired, upgrade to the latest firmware 4.35 to avoid the issue.
  • jw708
    jw708 Posts: 16  Freshman Member
    I've just had this same issue with a password reset starting with '
    Is restoring from a backup the only option here?
  • jw708
    Should say I downloaded startup-config.conf before the update, is that the correct file to restore?
  • If I don't have a backup, is there any way to get in and reset the password? This forced password change really messed me up. Is it worth it to make us do this and lock us out? My router was running fine. Now it is almost a brick.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    You can refer to this thread to backup configuration if you lost your password.
    And send out your configuration by new firmware.
    https://community.zyxel.com/en/discussion/comment/35202#Comment_35202
