MG-105 upload speed limited with Livebox 6 (Orange)
Zyxel_Melen said:Hi @jlucG,
Thanks for your information.
We received one of our customer's feedback that he said the if he connect his PC to MG-105 first,
then connect MG-105 to livebox 6, the upload speed become normal.
May you try this steps and help to screenshot the interface status again if your upload speed also become normal?
About you question 1, I'm wonder about it too.
Not sure why orange arrange the interfaces like this, maybe you can ask Orange's support engineer.Hi Melen,I have tried what your customer said but i didn't notice any change whatever the order of the connections.To summarize :with connection direct box i get 2000/800 (problem ?)with connection via switch i get 2000/below 400 (problem for sure)jlucG0 -
Hi Melen,I just talked to an Orange engineer. He said to me that the maximum upload speed with their fiber connection is 800Mpbs.Since i'm curious i searched the net to see what happens within their brand contestants : free, sfr,... and it appears that the Orange's 800Mbps is the fastest one.So the problem is with the switch Zyxel which divide the speed by about 2.I would be curious to test another switch (other than Zyxel... sorry 😉) to see if there is the same issue...jlucG0
Hi Melen,You will be happy 😀 It seems there is no particular issue with the zyxel MG-105.As i told you previously i did the same tests with another switch (Netgear XS508M 10Gb)I found 2000 download and 800 uploadI was curious and repeated the test again with the Zyxel seconds later. I found 2000 download and 800 upload too.So I think that the Zyxel in not in question.I don't know what happened last week but certainly something independent of my will disrupted the network.And maybe the same thing happened to the other internauts in this forum...An alien cyber-attack ? 😁0
Hi @jlucG,
It's happy to hear your network is fine now.
May I know the firmware version of livebox 6 now you're using?
And may you share with me the screenshot of the interface status on livebox 6?
Did you change any cable? Because you said you're using 0.5M Cat7 cable to connect MG-105 and livebox 6.
Zyxel Melen0 -
Did you change any cable? Because you said you're using 0.5M Cat7 cable to connect MG-105 and livebox 6.Of course (see attached file)I didn't change anything except the time period of the experimentsThe config is :LB6 with port wan 2.5Gb going to switch connected to PCs (3)LB6 with port 1 going to a router connecting my home IoTLB6 with port 2 going to a connected doorbellLB6 with ports 3 & 4 emptyHope this will help 😀P.S : The temperature of the switch's casing is quite important (measured 51°C) so the heat inside must be much more...jlucG0 -
Hmmm! I spoke too soon...To day the upload speed drops down to 400Mbps again... tested with 2 differents switchesMay be there is a problem with the 2.5Gb port of the LB6 i think0
Hi @jlucG,
Do you mean you tested with 2 differents switches(not MG-105) and the result shows upload speed drop down to 400Mbps again?
Zyxel Melen0 -
Hi Melen,Sorry for this late answer.Yes it's what i mean.I contacted Orange and they are investigating.I must say that even if this issue occurs with other switches, with Zyxel it appears more often 😪And pursuing my experiences it appears that upload speed drops down to about 80Mbps sometimes...0 -
Hi @jlucG,This particular performance issue with Orange Livebox 6 is primary related to the inter-operability behavior due to the Green Ethernet Technology (EEE) supported by different chipsets.
It is random and the result may depends on either cable quality or cable lengths.
Kindly remind, all of the MG-105/108 has passed 2.5G wire-speed performance test at the time of manufacturing.So we recommend to contact your service provider to see if they can disable EEE remotely to overcome this issue.Zyxel Melen0
- 441 Beta Program
- 292 Service & License
