ATP500 and Hotspot
mkuru
mkuru Posts: 2 image  Freshman Member
Fourth Anniversary
Hello there We are using atp500 and we have 2 vlans. There is also Mikrotik in vlan10. I want to be in the hotspot Mikrotik, which will do the DHCP and atp500 logging. vlan10 ip address 10.0.0.1 , Mikrotik ip address 10.0.0.2 What path should we follow?
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    mkuru,
    Do you mean connect devices like these ?
    atp500(vlan10 interface:10.0.0.1) --- (vlan10 interface 10.0.0.2)Mikrotik(lan interface for hotspot)
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    edited May 2022
    If your topology like zyman2008 said,I think there are some point to notice
    1) ensure DHCP Pool of mikrotik won't conflict with ATP.
    2) if mikrotik didn't do NAT,ATP must have route to DHCP Pool
    3) If mikrotik would share the same ISP link ,  mikrotik shall set 10.0.0.1 as default route.
