Attempt to login to USG50, Chrome reports ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I cannot confirm. Depends not only from the "current" Google Chrome request, but also on the firmware version. Anyway, this is a way for disabling insecure cypher. https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=014475&lang=ENLyonsvt said:I would like to confirm that the USG50 can also be configured (using CLI or web interface) to increase its minimum security level so that current Google Chrome is satisfied.Lyonsvt said:Additionally, would this change impact any existing security definitions for VPNs?AFAIK it depends from the configuration of the VPN tunnels.USG50 has been updated last time during 2016 https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=MD09108&md=ZyWALL USG 50 The most updated firmware is a "weekly firmware", but currently i don't have any URL for that. Changing the device is strongly suggested, current "replacement" for USG50 is USG200 Flex (two proper WAN ports). USG 50 Flex could be also used due to a dual personality port (OPT/WAN2)5 -
Chrome browser is most current release.
VPN tunnels are using 3DES/SHA1, 3DES/MD5, AE2128/SHA1/ AES256/SHA1
Looks like I don't have the most current firmware BDS.9(C0) is available.
Hi @Lyonsvt ,
You can get the latest firmware from the link below.
https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=MD09108&md=ZyWALL USG 50
I think there is a mistake here... my post is about ATP 5000
I think the error being faced on Chrome appears due to a lack of “common SSL protocol version or cipher suite support” between a web server and a user’s browser. This issue happens during the TLS handshake process. To solve the issue, you can check out the following article:- https://certera.com/kb/how-to-fix-the-err_ssl_version_or_cipher_mismatch-error/.Error
Maybe it will help solve the error.
I think the error being faced on Chrome appears due to a lack of “common SSL protocol version or cipher suite support” between a web server and a user’s browser. This issue happens during the TLS handshake process. To solve the issue, you can check out the following article at Certera.com
- 588 USG FLEX H Series
- 477 News and Release
