Android 12 and ikev2
Hello DavideV,DavideV said:Hello everybody,guys i have the same s22 ultra with the same problem.I was about to buy the USG20-VPN mod but after reading this thread I stopped.So I ask you for an update on the situation. Is it possible to set ikev2 psk directly in android vpn section?I ask it because I would have bixby routinely manage the activation and deactivation of the vpn depending on whether or not it is under the same Wifi. And above all, avoid using third-party applications because they consume a train of battery. Thank you
So far, I didn't manage to get the S22 Ultra's VPN built in client working. It works flawless using Strongswan app as I wrote several time on here. But I had a chance to try an updated Google Pixel phone and it works. Using same settings, same parameters Google Pixel works fine, S22 doesn't ! So, according to my opinion, it shouldn't be a zyxel related issue.
Not sure if strongswan vpn get along with Bixby
Agor1 -
hi and thanks for the support.In practice they are in canvas pants if you are unable to enter the parameters in the s22 and actually bixby cannot activate / deactivate the tunnel from an app.
But does ikev2 PSK also have problems?
Could you tell me maybe with a screenshot what mistake it makes?
So I post it on the samsung community. Thank you0 -
So is there any conclusion for IKEv2, my S21 phone wouldn't connect too. L2TP works just fine.0
You may need to play around with the Key group and encryptionPeppino said:So is there any conclusion for IKEv2, my S21 phone wouldn't connect too. L2TP works just fine.
VPN Server role IKEv2 broken as far as I can tell — Zyxel Community
VPN Server role IKEv2 broken as far as I can tell — Zyxel Community0 -
Set for VPN gateway domain name / Ipv4 to 0.0.0.0
in VPN connection set loacl poilcy with host IP 0.0.0.0
check Related Settings zone is IPSec_VPN
Hi @Peppino,
Samsung uses DH24 by default but our device only supports up to DH21. DH24 is less secure than DH21. It is not recommended option. Please install Strongswan APP on S21.
3 -
StrongSwan Android from StrongSwan ProjectDocumentation about Android VPN client
Thank you Cooldia,Zyxel_Cooldia said:Hi @Peppino,
This makes things clearer, appreciate your answer.0 -
Hello Cooldia and thanks for the explanation.In fact, it was days that I kept beating my head trying to configure an s22 ultra with a USG20-VPN and in any case I have not succeeded. But now at least I know why.Do you think it will be possible to implement DH24 on your devices in the future? Thanks1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
