zywall 110 failing PCI Compliance port 500(isakmp)
ip http secure-server strong-cipher
no ip http secure-server tlsv10
But this particular router seems to have an issue I have not seen on the other. The 500(isakmp) venerability. I am not set to aggressive mode. Negotiation mode is Main. Is there a lockdown for the 110?
I am running V4.32(AAAA.0) for firmware.
basic setup. Just internet access and VPN for IT support to connect. I have even locked down the source address for the VPN's to IT support only.
Is this Firewall not capable of securing this like the other newer firewalls I have. Even the USG20 passes with no issues.
from Zyxel support:
If you have a VPN configured it is likely recognizing the 3DES and DES algorithms used on this VPN. You will either need to block IKE (port 500) from the outside or increase the strength of the algorithms.
Keep in mind that L2TP uses 3DES and DES algorithms to work so you will not be able to use L2TP, and you may need to switch to the IP Sec VPN client.
SSL VPN may not work either as it uses port 443 and this may not be allowed depending on the PCI scan. You can change this port number however to something like 4434 or 444. The clients would need to type in the public IP with a colon and the new port number. For example 1.2.3.4:4434. Note that this would require a policy control rule to allow port 4434 (or what ever port you chose) From WAN To Zywall.
What is funny is that I Have another client with the same IPSec L2TP and it passed just fine. it is a USG-20 I did have to block tls v1.0 with:
and the scan passed with no issues.
- 588 USG FLEX H Series
- 476 News and Release
