What are GS1900-24E firmware 2.6(AAHC.3) ssh console commands?
Hi @EerWie,
I would like to inform that GS1900 series are smart managed switch which means you may only configure the switch via web GUI. If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series.
Hope it helps.Jonas,0 -
Actually you could log in with ssh if enabled. So there should be the list of used commands somewhere.BR
So what is the command list?0
Hi @bensegar,
Welcome to Zyxel community!
Since GS1900 series is a smart managed switch which does not support CLI command to configure.
You may only configure the switch on web GUI.
If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series..
Zyxel Melen0 -
I check my GS1900-8HP and find some commands can use, you can check my attachment.bensegar said:So what is the command list?
But GS1900 could not configure via CLI, just like Jonas and Melen said.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
