Help with routing from site 1 to site 3 (site1==site2==site3)
2»
    edited May 2022
    After setting it up here by locally you don't need the concentrator
    Did all site to site with IKEv2 and doable even with dynamic IP by Site-to-site with Dynamic Peer
    site A ping from 192.168.254.134 to site C 192.168.255.52
    Site A USG60W
    WAN2 dynamic IP
    LAN1 192.168.254.129/255.255.255.128
    VPN gateway to site B 192.168.254.1
    VPN connection site-to-site
    Nailed-Up
    Gwtozywall110_local
    local policy 192.168.254.128/26
    remote policy 192.168.138.0/28
    routing rule
    Interface LAN1
    destination address 192.168.255.48/28
    next hop VPN tunnel
    Tuneltozywall110_local
    Site B Zywall 110
    OPT 192.168.254.1
    VPN gateway to site A Dynamic Address
    VPN connection Site-to-site with Dynamic Peer
    GwtoUSG60W_local
    local policy 192.168.138.0/28
    remote policy 192.168.254.128/26
    VPN gateway to site C 192.168.255.247
    GWtoVPN300_local2
    remote policy 192.168.255.48/28
    routing rule
    Tunnel TuneltoUSG60W_local
    next hop VPN tunnel
    TuneltoVPN300_local2
    Site C VPN300
    Ge3 192.168.255.247
    Ge5 192.168.255.48  /  255.255.255.240
    VPN gateway to site B 192.168.255.202
    GWtozywall110_local2
    local policy 192.168.255.48/28
    routing rule
    Interface Ge5
    destination address 192.168.254.128/26
    next hop VPN tunnel
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @OldFox,
    1)Kindly check the VPN  profile which connected site3 on site2 ,The local policy(phase2) shall involve site1 subnet.
    2)Another solution. Concentrator can apply in your scenario.Please find following the handbook (Started At  Page 87)
    https://download.zyxel.com/ATP700/handbook/ATP700_ZLD5.20_Handbook.pdf
    If the issue still persist,Could you share your all configuration in Private Message ? We would assist you to check.
    Thank you
    Kevin
  • OldFox
    OldFox Posts: 16 image  Freshman Member
    Hi @OldFox,
    Thanks for the hint, that would probably work and I'll definitely try it out.
    Currently I've switched to PLAN-B and did the following:
    - switched from "Remote Access (Server Role)" to "Site-to-site with Dynamic Peer"
    - switched to IKEv2 with certs auth.
    - created another tunnel from site3 to site 1, so I have 3 tunnels now:
          Site1
    Site2 --   Site3
    Thanks for your help guys!
