Zywall USG 110 Not booting
Square_Bear
Hello
I have a Zywall USG 110 (old one) which is not booting.
In Console I can see the following:
Thanks,
Square_Bear
I have tried to upload the latest "471AAPH0C0.ri" but it just says this:Error trying to mount db partition 5 timesmke2fs: No such device or address while trying to determine filesystem sizemke2fs: No such device or address while trying to determine filesystem sizeCheck partition table error: 1Recovering Partition ...
Is there a way to recover it? Maybe an older recovery image?Starting XMODEM upload (CRC mode)....CCProduct model id is not compatible!!This product's model id is 9703The kernel image supports the following product model id :</code><br> <code>ERROR
Thanks,
Square_Bear
Hi @Square_Bear,For Restoring Firmware and Database, Please find the following link1)Enter to debug mode2)a. atcd 1b. atkz -f -l 192.168.1.1c. atgof3)After boots up, connect your network cable to USG Port1 and change IP address as the same subnet in 192.168.1.0/24.4)Using FTP put the *.bin ,after complete then repeast above step put the *.db
Kindly let's me know if you need future assistance.Thanks
Kevin0 -
Hello @Zyxel_KevinThank you very much for your help!
I tried your suggestion but it is not working. Entering atcd 0 does this:ZyWALL 110> atcd 0
Change Boot Number=0And hangs infinitely.I restarted in the debug mode and did the steps you described in 2) b., but after atkz and atgof it just hangs again with the same entries as in my first post.Is there another Way?Many thanks,Sqare_Bear
Hi @Square_Bear,
Change step2(a) Command2)a. atcd 1 or atcd 2
Please kindly check again. If the issue persist.I would like to have remote session for this .
Kevin0 -
Hello @Zyxel_Kevin,I tried atcd 0 to atcd 3. It always says "Change Boot Number=[number I entered]" and hangs after this.
How can we get in contact for a remote session?Thanks,Sqare_Bear
Hi @Square_Bear,
Thank for your feedback.
May we have remote on 5/12 or 5/13. We can start at 9:00 (your time)
Kindly provide your remote credential in PM.
Thank you
Kevin0
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
