USG FLEX 100 - DHCP: PC obtain ip from router
LucaSantamarianova
in Security
Hi!!
I have this network:
ONT FTTH
AVM fritzbox -------- ATM (DHCP)
192.168.188.1
192.168.188.10 static
USG FLEX 100
LAN1
192.168.100.1
dhcp SERVER ENABLE
LOCAL LAN SWITCH UNMANAGED
I have a big problem:
from some days, if I leave a dhcp client enable on lan the address assigned is 192.168.188.x from AVM.... But I have a USG in the middle!!!!
if I set IP address manually (192.168.100.x) is all ok
I'm go to crazy....
this system is installed on october 2021.... is all ok... but from some days I have this problem
thanks
Is there any wrong physical link connected from Fritzbox to unmanagement switch?Also, did you configure any bridge interface on FLEX100? What's the IP address offered to you if connect direct PC to FLEX100 LAN port? (disconnect the unmanagement switch from FLEX100 prevent any affect)0
- 588 USG FLEX H Series
- 476 News and Release
