ZyWALL ATP200 how to start with Vlan?
Username_is_reserved
in Security
Here is my Network in a very simplified way:
The ATP (will) have 2 Wan Connection one slow DSL and one fast but unreliable Cable.
There are multiple Switch in the System 2 Zyxel and a Handfull Managed and Unmanaged one. I use an Netget for example for PoE to power the AP and some IP Phones.
I intend to have atlest 4 Vlans for: Guest, IP Phone, Business, Home stuff. Currently everything run on the old USG without a VLan.
So how to make it easy to Switch "just" the Lan cable from the old to the new Router?
Hi @Username_is_reserved,
Greeting forum , this is my suggestion. I
For exapmle : vlan 10 AP,vlan 20 IP phone,vlan 30 home stuff,vlan 40 Client1) All UPLINK of Switch using 802.1Q, and allow tag all vlan.
I am not sure what's your AP level/topology.Maybe It should using 802.1Q on switch port which connect to AP and tagging vlan10,30 .
2) Setting the vlan on individual switch ports (vlan10 for AP,Vlan20 for IP Phone, etc.)
-In order to look clean, you may also make switch port 1-6 vlan10,7-12 vlan20,etc . But you have to sort out the cable.3) Setting Vlan address on ATP200 ,(Assuming LAN2 Connect to internal switch)
-These are VLANS Gateway , All traffic between vlan will pass through the firewall .
Kevin1 -
Zyxel_Kevin said:Hi @Username_is_reserved,
For example : vlan 10 AP,vlan 20 IP phone,vlan 30 home stuff,vlan 40 Client1) All UPLINK of Switch using 802.1Q, and allow tag all vlan.
Kevin
Thanks for replay. The are WAC APs.
How to prevent that I cant access anything any more when I set a Vlan?I guess I must do a VLan Trunk when I setup the Switch?When the Switch in the Vlan 10 and the Guest connect to the Wifi AP the should get in there own Vlan (sry I got confused by my own Diagram) lets say Wifi Guest are Vlan 50...For the Guest I should activate: Layer 2 Isolation to I guess?Is there a good "How To" for the "Web Authentication"?
How to prevent that I cant access anything any more when I set a Vlan?-Kindly using Mgmt Port to set up Switch to prevent loss connection.please notice you must need downtime to do the vlan change.I guess I must do a VLan Trunk when I setup the Switch?-Yes, All uplink between switch must have 802.1Q .When the Switch in the Vlan 10 and the Guest connect to the Wifi AP the should get in there own Vlan (sry I got confused by my own Diagram) lets say Wifi Guest are Vlan 50...-The switch port which connect AP must have 802.1Q as well.For the Guest I should activate: Layer 2 Isolation to I guess?-Yes, Layer 2 isolation in AP.Is there a good "How To" for the "Web Authentication"?-Please Kindly find our hand book (Page 571~576),Thanks1 -
Sorry everyone its still me. Now I want start to change. I see some Device like an IP Phone should support adding an Vlan ID. Should I add the Vlan ID there to?
The confusing part is why the Vlan is part of the Zone/ Port?!
As far as I know, the vlan setup on sip phone is named voice VLAN with tagging. The purpose is to separate the voice stream and data stream.
-So do the appropriate settings on swtich after you added voice vlan.
-Create vlanXX interface if the voice stream will goto internet.
I found some FAQ talk about Voice VLAN
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 296 Service & License
- 461 News and Release
