Help with routing from site 1 to site 3 (site1==site2==site3)
After setting it up here by locally you don't need the concentrator
Did all site to site with IKEv2 and doable even with dynamic IP by Site-to-site with Dynamic Peer
site A ping from 192.168.254.134 to site C 192.168.255.52
Site A USG60W
WAN2 dynamic IP
LAN1 192.168.254.129/255.255.255.128
VPN gateway to site B 192.168.254.1
VPN connection site-to-site
Nailed-Up
Gwtozywall110_local
local policy 192.168.254.128/26
remote policy 192.168.138.0/28
routing rule
Interface LAN1
destination address 192.168.255.48/28
next hop VPN tunnel
Tuneltozywall110_local
Site B Zywall 110
OPT 192.168.254.1
VPN gateway to site A Dynamic Address
VPN connection Site-to-site with Dynamic Peer
GwtoUSG60W_local
local policy 192.168.138.0/28
remote policy 192.168.254.128/26
VPN gateway to site C 192.168.255.247
GWtoVPN300_local2
remote policy 192.168.255.48/28
routing rule
Tunnel TuneltoUSG60W_local
next hop VPN tunnel
TuneltoVPN300_local2
Site C VPN300
Ge3 192.168.255.247
Ge5 192.168.255.48 / 255.255.255.240
VPN gateway to site B 192.168.255.202
GWtozywall110_local2
local policy 192.168.255.48/28
routing rule
Interface Ge5
destination address 192.168.254.128/26
next hop VPN tunnel
Hi @OldFox,
1)Kindly check the VPN profile which connected site3 on site2 ,The local policy(phase2) shall involve site1 subnet.
2)Another solution. Concentrator can apply in your scenario.Please find following the handbook (Started At Page 87)
https://download.zyxel.com/ATP700/handbook/ATP700_ZLD5.20_Handbook.pdf
If the issue still persist,Could you share your all configuration in Private Message ? We would assist you to check.
Thank you
Kevin0 -
Thanks for the hint, that would probably work and I'll definitely try it out.Zyxel_Kevin said:Hi @OldFox,
Currently I've switched to PLAN-B and did the following:
- switched from "Remote Access (Server Role)" to "Site-to-site with Dynamic Peer"
- switched to IKEv2 with certs auth.
- created another tunnel from site3 to site 1, so I have 3 tunnels now:
Site1
Site2 -- Site3
Thanks for your help guys!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
