4.30 SIP ALG issues
Hi @grokit
In our test scenario these kind the scenario the SIP OPTION are able forwarding to LAN side successfully
Topology#1: Phone#A-------[LAN]------USG-----[Internet]-----SIP server & Phone#B
Topology#2: Phone#A&B-------[LAN]------USG-----[Internet]-----SIP server
SIP ALG setting:
Here is the packets captured on USG:
WAN side IP:
LAN side packets:
May we have a check on your packets? Please just feel free send me by private message.
hi @Zyxel_Stanley
Yes, this is exactly the same setup I have. All options and serttings identical. All traces look the same in my case. But only with FW 4.25.
As soon as I install FW 4.30, 4.31 or 430AAPJ0ITS-WK10-r82493, I would not see the SIP Option packets on the LAN side anymore. Or to be more precise, I would see a few SIP Options only, probably the ones for which the SIP sessions were active.
I would see, on the other hand, a lot of blocked incoming SIP in the firewall log. Blocked by the Default rule and obviously the SIP OPTIONS pakets for which there was no SIP session anymore.
With FW 4.25 I have about 20-30 open SIP sessions in session monitor at any time, and no blocked pakets in the firewall log.
With FW 4.30 I see only half a dozen SIP sessions at any time, and lots of blocked packets in the firewall log.
I did not check this with the other FW's.
@R_I
Reto, you mentioned you'd see the same behaviour than I see. Can you recall if you have seen lots of blocked incoming SIP packets in the firewall log too?
Daniel0 -
Daniel, I'm afraid I can't be of any help here; I had no time to investigate the problem and immediately switched back to 4.25.
With 1 trunk connection (Aastra pbx to sipcall, 6 lines) my USG110 currently shows 24 open SIP sessions.0 -
Merci Reto,
No Worries.. Thanks anyway.
grüessli
Daniel
We are seeing the same issues on a few of our USG60 devices with larger numbers of VOIP phones connecting to a cloud PBX. We have all of the SIP ALG options disabled and have not had any problems before. We get a large amount of blocked traffic coming back from the cloud PBX, it seems as if there is some problem with rport, but I am not sure. I am in the process of reverting back to 4.20 as it is the only older firmware version that I have access to.0
Hi @TAPTech
I will send you private message for check this issue more detail.0 -
Hi @grokit
Unfortunately I don't think my situation will help you much. I found that our issue was not due to firmware. After downgrading to 4.25, it still happens. We were getting dropped calls, which were due to 3 of the SIP phones on the network having outdated SIP user passwords and failing to authenticate. For whatever reason, this caused a lot of problems with the other 12 phones. After resolving those issues, the problems went away.
We were seeing phones that would not stay registered via keep-alive.
WE STILL see some blocked traffic from the cloud VoIP PBX, but there are zero issues with calls. So we will need to investigate that a little bit more.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
