Rerouting internal Requets to our external IP back towards the intern Target
MartinK
MartinK Posts: 1 image  Freshman Member
edited April 2021 in Security
Hi Folks
Is there a simple way (rule) to reroute internal clients which are accessing our web servers (intern) and using by accident the outer/external IP-Address.
We try to use internal DNS-resolution so that internal clients get a internal address for some services. However it still happens, that clients us external DNS-Sources and therefor try to access form inside our external IP-Addresses.
Any hints would be appreciated
Best regards, Martin
  • Zyxel_Stanley
    Welcome to Zyxel community.
    Currently USG does not support redirect DNS traffic function.
    But as your scenario, LAN side client still accessing internal server by WAN side IP via NAT rule.
    You can disable “NAT loopback” function in your NAT rule.
    After disabled NAT Loopback function, LAN side client is unable accessing to your server by WAN side IP anymore.
    But please inform your users, setup your internal DNS server IP on their PC avoids unable accessing to internal server.
