UTM and UTM License Question
businessuer
in Security
What is the difference between NGFW and UTM FW?
Can anyone help explain the features of the UTM Security Pack and what it does?
Hello @businessuer,Currently USG FLEX series and ATP series are the successors of the NSG series.We could divide our firewalls into two categories, Cloud-managed and Stand-alone managed. USG FEXL series and ATP series are able to install on both cloud mode and standalone mode, NSG series is only for cloud mode.The NSG and USG Flex main difference as below:USG Flex will have:1. NebulaFlex (hybrid mode).2. Security profile synchronization to multiple sites.3. Supported more than 2 WANs.4. Improve UTM performance and leveraging ATP's malware protection technology.For UTM Security features, please refer to the information and EDM below
https://www.zyxel.com/library/assets/solutions/security-license-solution/download/security_license_for_web_download.pdf
Thanks,
James0 -
In that case for the NSG, can I use zon utility to control it?0
Zyxel_James said:0
Hello @businessuer,Yes, NSG series is cloud mode only, so ZON utility doesn't have much control over NSG, it still able to access web gui, reboot device, upload local firmware file...James0
Zyxel_James said:Hello @businessuer,Yes, NSG series is cloud mode only, so ZON utility doesn't have much control over NSG, it still able to access web gui, reboot device, upload local firmware file...James0
Hi @businessuerIt's the same as NSG cloud mode web gui, you may change the WAN address, collect diagnostics info, packet capture...If you're saying set up configure, NSG is only controlled by Nebula CC.Thank you.James0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
