Various random VPN reconnects
Hi Everybody,
I'm lately encountering random reconnects on my VPN-Connection when transceiving large Files via SMB and/or HTTP.
It looks like the following example in the Zywall Log
My setup is as the following: IPSEC IKEv2 VPN with an IPv4only public WAN Adress using a native Win10 VPN Client. When using RDP Connection this behaviour is not occuring for some strange reason.
Has Anybody an Idea, what could be the root cause for this errors?
Many Thx in Advance
Batzn
Hello @Batzn,Thanks for your feedback.Which model/version do you use, we will clarify this problem.Could you provide the complete IKE logs and the debug log when the transmission, and how large is the transceiving file?For collecting debug logs, please turn on debug level log, go to Configuration > Log&Report > Log Settings > System log or Log Category Settings, then select debug level for IKE, IPsec.Thank you.
James0 -
Hello @Batzn,May I know your scenario and the frequency of the problem?For exampleWin10 VPN client ------ ZyWall -----HFServerJames0
Hello James,thanks for helping me with my issue. I try to provide as many information as possible. My Firewall is an USG20VPN (Firmware is up-to-date). The reconnects are happening every 3-5 Minutes when uploading 3-4GB of data to the remote NAS. When RDPing the reconnects delay to about 60-70 minutes.I lately was RDPing for 4 hours, the connection is stable and performance is absolutely OK. Users don't recognize the rekeying issue, troughput for SMB and FTP is maxing out the line!My scenario is Win10/11native VPN Client === WAN === USG20VPN === NASBy setting logging to debug (this was the missing element) I found out that obviously rekeying the Tunnel is the problem. For me it seems that there must not only be a time-based rekeying trigger but also an amount-based one(you cannot see in the WebIF but in CLI). I'm providing the logs later because right now I cannot access them.Thx a lotBatzn0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
