UTM and UTM License Question
businessuer
businessuer Posts: 134 image  Ally Member
What is the difference between NGFW and UTM FW?
Can anyone help explain the features of the UTM Security Pack and what it does?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    edited May 2022
    Currently USG FLEX series and ATP series are the successors of the NSG series.
    We could divide our firewalls into two categories, Cloud-managed and Stand-alone managed. USG FEXL series and ATP series are able to install on both cloud mode and standalone mode, NSG series is only for cloud mode.
    The NSG and USG Flex main difference as below:
    USG Flex will have:
    1. NebulaFlex (hybrid mode).
    2. Security profile synchronization to multiple sites.
    3. Supported more than 2 WANs.
    4. Improve UTM performance and leveraging ATP's malware protection technology.
    For UTM Security features, please refer to the information and EDM below
    https://www.zyxel.com/library/assets/solutions/security-license-solution/download/security_license_for_web_download.pdf
    Thanks,
    James
  • businessuer
    In that case for the NSG, can I use zon utility to control it?
  • Zyxel_James
    businessuer,
    NSG series is supported by Zyxel One Network Utility
    Thanks,
    James
  • businessuer
    businessuer,
    Thanks,
    James
    But you say NSG series is cloud mode only, so why I can control it using zon utility?
  • Zyxel_James
    Yes, NSG series is cloud mode only, so ZON utility doesn't have much control over NSG, it still able to access web gui, reboot device, upload local firmware file...
    James
  • businessuer
    James
    But can I use the web gui to do stuff?
  • Zyxel_James
    It's the same as NSG cloud mode web gui, you may change the WAN address, collect diagnostics info, packet capture...
    If you're saying set up configure, NSG is only controlled by Nebula CC.
    Thank you.
    James
