Inter vlan routing
hi
We have configured several vlans on a usg 60.
The goal was to separate vlans but all our vlans communicate with each other.
For exemple vlan 10 (192.168.10.0/24) can ping devices on vlan 20 (192.168.20.0/24)
We did not create any route.
How to block the communication between the vlans ? in rules policy ?
Thank you in advance
Frantz
Frantz
Hi @eGuyane
You can make sure both of VLANs are belonging in same Zone or not.
Go to Configuration > Object > Zone.
If both of VLANs are belonging the same zone, you can setup the policy control rule by IP base to block the traffic.
Or you can define VLAN interfaces are belonging different zone.
And setup the policy control rule by zone base.
5
Hi @eGuyane
5 -
Thank you0
- 431 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 359 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
