Issues when upgrading from 5.21 to 5.30 when ATP 500 hardware is in HApro
nikita92
nikita92 Posts: 7 image  Freshman Member
I click download updates from the server and update
The passive ATP500 is being updated, the active hangs (but continues to work) Writes that the download is in XA and hangs for several hours
After that, it starts working without error, the active one remains on the old firmware, the passive one is updated and HApro falls into an error
What could be the problem ?
  • Fred_77
    Fred_77 Posts: 147 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Hi @nikita92
    i'm planning the same activity on a customer site; and would like  avoid  same issue. Could you confirm you have started the update from the running fw and not from the stand-by one?
  • Zyxel_Cooldia
    Hi @nikita92,
    For On-Premises mode with High Available (HA) feature enabled, please DO NOT use cloud firmware upgrade. You will need to follow a different procedure to complete the firmware upgrade, please read the SOP. * Applicable models and versions: USG FLEX 500/700, ATP500/700/800 with ZLD5.20 through ZLD5.21 Patch1.
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Is reported into release notes or into user manual?
    ZLD5.21 Patch1.
    Is it in test?
  • Zyxel_Cooldia
    ZLD5.21 Patch1.
    Is it in test?
    It is in release note read me section. Both V5.20 and V5.21 patch1 will encounter this issue via cloud firmware update.
