Issues when upgrading from 5.21 to 5.30 when ATP 500 hardware is in HApro
I click download updates from the server and update
The passive ATP500 is being updated, the active hangs (but continues to work) Writes that the download is in XA and hangs for several hours
After that, it starts working without error, the active one remains on the old firmware, the passive one is updated and HApro falls into an error
What could be the problem ?
Hi @nikita92,
For On-Premises mode with High Available (HA) feature enabled, please DO NOT use cloud firmware upgrade. You will need to follow a different procedure to complete the firmware upgrade, please read the SOP. * Applicable models and versions: USG FLEX 500/700, ATP500/700/800 with ZLD5.20 through ZLD5.21 Patch1.
Zyxel_Cooldia said:For On-Premises mode with High Available (HA) feature enabled, please DO NOT use cloud firmware upgrade.
Is reported into release notes or into user manual?Zyxel_Cooldia said:ZLD5.21 Patch1.
Is it in test?0 -
mMontana said:Zyxel_Cooldia said:For On-Premises mode with High Available (HA) feature enabled, please DO NOT use cloud firmware upgrade.
Is it in test?0
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
