USG Flex 200 - L2TP over IPsec, not working after firmware 5.30
syraarpe
syraarpe Posts: 7
image  Freshman Member
Hello there
After upgrading Flex 200 from firmware 5.20 to 5.30, our users cant sign in anymore.
Anyone get the samme error.
We are using RADIUS for Duo.
If we create a local test-user in the Flex200, its works.
But then our duo/2-factor not working
Solution is to run users on the "Local" So radius is not working anymore.
  • syraarpe
    syraarpe Posts: 7
    @mMontana
    We found it.
    They have made a change for concatenate auth, so its enabled by default.
    Works again.
    Case closed.
  • mMontana
    mMontana Posts: 1,514
    image  Guru Member
    Verify the paths and credentials for accessing from USG Flex 200 to Radius. Also, change log details for debugging if the appliance can:
    • contact the server
    • access the server
    • query the user
    • and the user data is provided back to the device
  • syraarpe
    syraarpe Posts: 7
    @mMontana
    We found it.
    Works again.
    Case closed.
  • mMontana
    image  Guru Member
    Thanks for sharing the correction made for solving the issue @syraarpe.
    Thanks also for trusting the recheck of parameters. Sometimes the assumption "worked before" is the worst partner for problem solving. :-)
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,591
    image  Zyxel Employee
    Thanks for the issue report. COA should not be tick after firmware update.  I will report this issue internally.
  • Zyxel_Cooldia
    Status update. This issue will be fixed in next firmware.
