Why the outside port don't work
itdsc
itdsc Posts: 2 image  Freshman Member
Second Anniversary
USG40W
Add of the internal ip adress 192.168.1.171 in the range of lan1
After
Add of a service on a tcp port 8790
Add of a group and in these grp add the service.
All was saved all seems like an other objet. No error encounters.
Add of a nat rules :
Apply button was pressed.
Add of two policy rules :
Port closed. could you help me ?
    PeterUK Posts: 4,435 image  Guru Member
    Is your WAN port set with the WAN IP or behind NAT?
    Set rule 1 with source IPv4 to any
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @itdsc,
    Thanks for @PeterUK point out the problem.
    Set Security Policy rule 1 source IPv4 to "Any"
    Thank you.
    James
  • itdsc
    Second Anniversary
    After the change nothing change the port is always closed
  • Fred_77
    Fred_77 Posts: 147 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Hi @itdsc
    i think you should modify your policy like this
    also check your nat roule; "Ip Originale" = any
    Fred
  • Zyxel_James
    Hello @itdsc,
    For your NAT rule, please set Source IP to "any", and your security policy rule 2 is not needed.
    Moreover, once the NAT rule is created, the external port should be open, we're not sure the online port scan works correctly on our device.
    If it still no work, please capture the packets on both WAN and LAN interface, provide to me through PM for further checking, thank you.
    James
