Throughput on DMZ port without UTM
Hi
My Internet connection has a raw download speed of 1 Gbit/s. When I run a speed test directly behind my modem without going through the firewall, I get a DL speed of around 870-930 Mbits/sec.
If I run the same test connecting on port 7 of my USG110, where I have a security policy rule with no UTM service at all, the speed drops to around 300 Mbits/sec.
Shouldn't I expect a higher speed there? Why does my USG slow down the speed so much even if I have not configured any UTM service on that port?
When I least tested the speed of my Zywall 110 which has the same Firewall throughput you might get 600Mb
Do the following for more speed
https://community.zyxel.com/en/discussion/4494/tip-for-getting-faster-throughput-on-usg-vpn-zywall
only problem is the option gets checked on reboot
Hi @wabla47,
Welcome to Zyxel Community. It should be able to reach 4xx mpbs without UTM service.
Please follow PeterUK's suggestion to disable collect statistics at monitor > system status > traffic statistics0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
