Throughput on DMZ port without UTM
Hi
My Internet connection has a raw download speed of 1 Gbit/s. When I run a speed test directly behind my modem without going through the firewall, I get a DL speed of around 870-930 Mbits/sec.
If I run the same test connecting on port 7 of my USG110, where I have a security policy rule with no UTM service at all, the speed drops to around 300 Mbits/sec.
Shouldn't I expect a higher speed there? Why does my USG slow down the speed so much even if I have not configured any UTM service on that port?
When I least tested the speed of my Zywall 110 which has the same Firewall throughput you might get 600Mb
Do the following for more speed
https://community.zyxel.com/en/discussion/4494/tip-for-getting-faster-throughput-on-usg-vpn-zywall
only problem is the option gets checked on reboot
Hi @wabla47,
Welcome to Zyxel Community. It should be able to reach 4xx mpbs without UTM service.
Please follow PeterUK's suggestion to disable collect statistics at monitor > system status > traffic statistics0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
