Why the outside port don't work
USG40W
Add of the internal ip adress 192.168.1.171 in the range of lan1
After
Add of a service on a tcp port 8790
Add of a group and in these grp add the service.
All was saved all seems like an other objet. No error encounters.
Add of a nat rules :
Apply button was pressed.
Add of two policy rules :
Port closed. could you help me ?
After
Is your WAN port set with the WAN IP or behind NAT?
Set rule 1 with source IPv4 to any
After the change nothing change the port is always closed
Hello @itdsc,For your NAT rule, please set Source IP to "any", and your security policy rule 2 is not needed.Moreover, once the NAT rule is created, the external port should be open, we're not sure the online port scan works correctly on our device.If it still no work, please capture the packets on both WAN and LAN interface, provide to me through PM for further checking, thank you.James0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
