USG Flex 200 - L2TP over IPsec, not working after firmware 5.30
Hello there
After upgrading Flex 200 from firmware 5.20 to 5.30, our users cant sign in anymore.
Anyone get the samme error.
We are using RADIUS for Duo.
If we create a local test-user in the Flex200, its works.
But then our duo/2-factor not working
Solution is to run users on the "Local"
So radius is not working anymore.
Verify the paths and credentials for accessing from USG Flex 200 to Radius. Also, change log details for debugging if the appliance can:
- contact the server
- access the server
- query the user
- and the user data is provided back to the device
Thanks for the issue report. COA should not be tick after firmware update. I will report this issue internally.
Status update. This issue will be fixed in next firmware.1
- 243 Nebula Ideas
- 6.9K Security
- 790 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 326 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
