Session logs with Date
Hi MarloWYes, USB storage is workable too.
(1) Plugin USB to UAG. And enable USG function.
Configuration > System > USB Storage > Enable USB storage service.
(2) Go to Configuration > Log & Report > Log Setting > Enable USB storage.
Enable "traffic log" in log setting.
(3) You can download the log by Maintenance > Diagnostics > System log .
5
Hi @MirkoW
The sessions in monitor > system status > session monitor page will show the current existing sessions on UAG. It will disappear after session is timeout.
But you can record all of the sessions history to external syslog server.
1. Go to Configuration > Log & Report > Remote Server 1
Enter your syslog server address and enable “Traffic Log”.
2. Then you can record all of the session logs on your server.
It will including time/username and source/destination address.
thanks for this solution. There are other methods available without using external servers ? For example USB Storage?0 -
5 -
cool, it works !!
thanks!!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
