USG Limitation of DHCP6 DUID of 41 characters! - any clues?
Hi USG-philes and Zyxel-lads...., can't configure Ubuntu18 Desktop IPV6 DHCP6 DUID longer than 41 characters into USG60/40 at firmware V4.32( 2018) .
Using STATEFUL DHCP with DHCP renovations to service DNS.....
-------> Configuration / Objects / DHCP6 / Lease / Add / Add Corresponding / Lease Type / Prefix Delegation / DUID .
In the example below the dhcp6.client-id is an expanded string of
Refer Ubuntu18 Desktop example....:
/var/lib/NetworkManager/dhclient6-7??????f-4ba0-3b3d-????-33020?????33-enp3s0f0.lease
There is a limit of 41 characters in the above field.
Yes can workaround this , however this limitation is possible coding laziness at the s/w end in 台湾
Any Clues?
B/R
Warwick
Hong Kong
x'00:ee:39:51:46:22:74:01:21:19:f1:ad:ac:f2:ac:0d:02:26'
default-duid "\000\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\231&";
lease6 {
interface "enp3s0f0";
ia-na a3:07:09:41 {
starts 1533638143;
renew 4294967295;
rebind 4294967295;
iaaddr 2001:xxx:xxx:xxxx::99:8 {
starts 1533638143;
preferred-life 4294967295;
max-life 4294967295;
option dhcp6.client-id <b>0:ee:39:51:46:22:74:1:21:19:f1:ad:ac:f2:ac:d:2:26</b>;
option dhcp6.server-id 0:4:0:6:70:99:96:21:7ee:ac;
lease6 {…..
Any Clues?
B/R
Warwick
Hong Kong
It is the same as other section, let's discussing it in other one. here5
- 439 Beta Program
- 2.8K Nebula
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
