ZyWALL USG 300 and TLS 1.2
Hi @alexey,The firmware 330AQV7ITS-WK48-r74988 is sent to you in private message.0
Hello!Zyxel_Jerry said:
Can you sent me firmware 3.30(AQE.7)ITS-WK48-r74988?
I have 5 devices ZyWALL USG 300 in different cities with fw 3.30(AQE.7), which doesn't have tls1.2
And maybe you have fw for ZyWALL USG 50? On it now installed 3.30(BDS.7)ITS-WK28-r72114
Update: i found all fw on the link from past messages
Thank you!0 -
Hi @AG_DM,You can find download link in this post.
Hello, I know the topic that is old, but I have the same problem with TLS 1.2 customer support on the Zyxel USG 300, I need software 3.30 (AQE.7) ITS-WK48-r74988 for TLS 1.2 support, I will be grateful if I was able to go again.Zyxel_Emily said:You need to upgrade ZyWALL USG 300 to the latest date firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support.
The firmware is sent to you in private message.
Edit:
I hurried up too much, the last entry in the thread concerns, in any case available for download helped me.
Edit2:Everything works!
Router(config)# show ip http server secure statusactive : yesport : 4440certificate : defaultforce redirect : noauthentication client: noanti beast attack : nostrong cipher suite : yescipher suite : aes 3des des rc4ssl protocol : tls1.2 tls1.1
I am shocked that there was a solution for such an old USG 300 router.Thank you very much!0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
