Zyxel USG20-VPN FireWall Update
toby
toby Posts: 1
Hi there,
I got an USG20-VPN the version is v4.65(ABAQ.1), I want to upload the newest version like v5.30(ABAQ.0). But I don't know why I can't successfully do it. Is there any other way I could try?Thanks for helping me.
Best regards.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,316  Zyxel Employee
    Can you describe how you update the firmware? via Web-GUI? Is there any error message appearing on Web-GUI or Monitor log? If you can provide the screenshot to us that would be better to let us understand your situation. Thanks.
  • Lansik
    Lansik Posts: 3
    Hello Zyxel_Jeff,
    we have same problem, USG20-VPN with V4.65(ABAQ.1), try to update to 5.30. From Cloud update finish with this error - Error: Firmware update fail – checksum error, code: 400. If I try local update to Standby, upload is running after it finish, old firmware is not replaced with new one.
    We try to upload older version 5.20, 5.21, not succesfully.
    Thanks for help.
    PeterUK Posts: 3,740  Guru Member
    Its come up before but you are unzip the file to upload the .bin ?
  • Lansik
    Lansik Posts: 3
    Checksum error is from Cloud update. Same problem I have on another USG, there are USG40 with 4.65 and trying update to 4.72.
  • Lansik
    Lansik Posts: 3
    And of course, only .bin file was uploaded.
