How to disable MESH? WX3401-B0
Lalle
Lalle Posts: 4 image  Freshman Member
edited May 2024 in Wireless
Hi, how do you disable Mesh on this router? Im not allowed to adjust the 2.4 and 5 ghz bands as long as its avtivated. On other routers it can easily be disabled under the wireless tab, there is no such mesh option on my router.
Best regards
  • Lalle
    Bump
  • YeK
    YeK Posts: 150 image  Master Member
    hi,
    Can you please share your fw version of device?
  • Lalle
    Hi, thanks for answering.
    Firmware is V5.17(ABVE.1)C0
  • Lalle
    Bump
  • YeK
    In current design, there is no way to disable “one SSID” for main 2.4G/5G. If you would like to have another SSID for different clients, please use Guest/More AP” page to configure it.
