Missing button "SSL VPN"on webpage
GeorgiTodorov
in Security
Hello, on ZyWALL 110, button "SSL VPN" dissapeared . Firmware version is 4.71 . A week ago there was a button . Any ideas ?
Hi @GeorgiTodorov,
Welcome to Zyxel community.We remove SSLVPN proxy mode since V4.65. You can install SSL VPN client for VPN service.
V4.65 release note3. [ENHANCEMENT] USG and ZyWALL series remove SSLVPN proxy mode and limit SSLVPN port access.
SecuExtender
https://www.zyxel.com/support/download_landing/product/secuextender_software_19.shtml?c=gb&l=en&pid=20140714181106&tab=Software&pname=SecuExtender Software1
Thanks, but this didn't resolve my problem. VPN is working fine. Downgrading firmware solve my problem.0
Hi @GeorgiTodorov
It seems to me that this has been the case since zyxel split the SSL port from the one for remote management. Fw 4.70 is the same. (not sure in 4.68)....
Fred0 -
Hi @GeorgiTodorov,
SecuExtender
https://www.zyxel.com/support/download_landing/product/secuextender_software_19.shtml?c=gb&l=en&pid=20140714181106&tab=Software&pname=SecuExtender Software1 -
If I understand you correctly, to use SSL VPN I need only installed SecuExtender and configured SSL VPN ?0
Hi @GeorgiTodorov,
Yes, install SSL VPN client to run full tunnel mode.0
- 434 Beta Program
- 172 Nebula Ideas
- 405 USG FLEX H Series
- 296 Security Ideas
- 43 Wireless Ideas
- 268 Service & License
- 413 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
