GS2210-48 and AIR-LAP1141
Recently have purchased the GS2210-48 and I am having issues connecting a AIR-LAP1141 WAP to the switch. I have the port tx tagging enabled as well as VLAN Trunking, PVID is on 1 (Management purposes)
I appear to have no packets traverse this port and I can not ping the default gateway of the router behind the switch. If I do connect ap to a dhcp enabled port it will obtain a dhcp ip but that is on a nontagged port and isn't what is needed
Any thoughts
Hello @Kevin_FT
What do you intend to configure SSID VLAN on your AP?
I assume that there are at least two SSID VLAN on AP. One is for management (VLAN1), while another is for general users. Am I right?
Can you share more details about your application?
Ryan0 -
I run 3 SSID's on the AP, 2 SSID's using vlan200 and 1 using vlan201. vlan1 is accessible on the AP for management purposes.
Currently we are using Cisco 800 Series Routers with a single uplink (Trunk, native vlan1) to the gs2210-48 (port 48) tagged and trunked. Ports 1-44 are all access vlan201 (Data) working fine. The AP is connected to port 47 currently, its tagged and trunked.
If I console into the AP I am unable to ping the default gateway (vlan1 ip) of the Cisco 800 series. If I bypass the gs2210-48 and connect directly into the router on a trunked port I can communicate through the AP correctly.
Hello @Kevin_FT
It seems that you have already configured setting properly.
How about PM me the configuration of GS2210 and I try to find the problem directly from it?
Besides, based on your description, I assume your topology looks like below. Am I right?
Ryan0
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
