Firmware
jvingaard
jvingaard Posts: 6 image  Freshman Member
edited April 2021 in Security
Where can i download firmware USG20W-VPN_4.25(ABAR.1)C0
    PeterUK Posts: 4,264 image  Guru Member
    edited August 2018
    It seems zyxel are not allowing you to get anything older then 4.30 by portal.myzyxel.com
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    edited August 2018
    Hi @ jvingaard
    Avoids user getting the same issues that we fixed, so website only allow to download last 3 versions.
    Is any reason that you have to downgrade to 4.25 version?
  • jvingaard
    Seams that any firmware after 4.25 are destroying my network, I have downloadet firmware
    4.20 from your FTP site, and it works greate.
    So what problems are you having with the new versions?
  • jvingaard
    Low internet speed, ISP dropout, Wifi connection problems etc
  • Zyxel_Stanley
    Hi @ jvingaard
    May we know more detail symptom after you upgraded to 4.32 firmware?
  • jvingaard
    Is the above not enough symptomes? :-o
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    @jvingaard
    I don't think so, for instance:
    --low internet speed ==> What's the original/after speed is it? UTM functions turned on after using 4.32?
    --ISP dropout ==> only happen on 4.32? my device doesn't have such problem, what the log says?
    --Wifi connection ==> I saw there're some wifi related issues in another thread, but my device doesn't use wifi so I can't tell, however, I did saw some wifi related fixes in the release note, maybe you can check if it's the same symptom as what you met.
