Firmware
Where can i download firmware USG20W-VPN_4.25(ABAR.1)C0
It seems zyxel are not allowing you to get anything older then 4.30 by portal.myzyxel.com
Hi @ jvingaard
Avoids user getting the same issues that we fixed, so website only allow to download last 3 versions.
Is any reason that you have to downgrade to 4.25 version?0 -
Hi,Seams that any firmware after 4.25 are destroying my network, I have downloadet firmware4.20 from your FTP site, and it works greate.0
So what problems are you having with the new versions?
Low internet speed, ISP dropout, Wifi connection problems etc
Hi @ jvingaard
May we know more detail symptom after you upgraded to 4.32 firmware?
Is the above not enough symptomes? :-o
@jvingaard
I don't think so, for instance:
--low internet speed ==> What's the original/after speed is it? UTM functions turned on after using 4.32?
--ISP dropout ==> only happen on 4.32? my device doesn't have such problem, what the log says?
--Wifi connection ==> I saw there're some wifi related issues in another thread, but my device doesn't use wifi so I can't tell, however, I did saw some wifi related fixes in the release note, maybe you can check if it's the same symptom as what you met.0
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
