How long until a fix is released for the VPN issues of firmware 5.30 ?
Breabl
Breabl Posts: 2 image  Freshman Member
Hello, I'm sure many of you are as frustrated as I am with the constant calls coming in about IPSec VPN all of a sudden not working, SSL VPN disconnecting after 2 minutes of idle time without reason and other sorts of related VPN Issues, Currently I am experiencing all the above mentioned issues variously throughout multiple locations that we have installed various ATP 200, 500, 800 models, ever since the lovely firmware update that came out to patch the critical vulnerability I happened to find out about from a third party source, instead of our actual partner, but hey here we are. :)
So to reiterate the topic, When will these issues be fixed and how long can we continue to advise our customers that "we are working on the issue" ? Thanks
