GS1920-48 from 4.50 to 4.70
Stoyan89
Stoyan89 Posts: 3  Freshman Member
Second Anniversary
edited August 2022 in Switch
Hello, I have GS1920-48v2 and upgraded to V4.50(AANZ.3) how to upgrade to 4.70(ABMJ.4)C0 for example. I can't find 4.60 on the site.
Kind Regards,
Stoyan
  • Zyxel_Adam
    Zyxel_Adam Posts: 430  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    edited June 2022
    Hi @Stoyan89.
    Looks like your GS1920-48 is version 1 since you are using frimware V4.50(AANZ.3), and that is the latest firmware version for GS1920-48v1. Please check our EOL list.
    Adam
  • Stoyan89
    Second Anniversary
    Hi Adam,
    Thank you for the reply! so even in the future will not be possible to upgrade further?
    Kind Regards,
    Stoyan
  • Download Library ; GS1920-24v2 GS1920-24v2 GS1920-24v2, Firmware Firmware Firmware  Hello, I have GS1920-48v2 and upgraded  cps test  to V4.50(AANZ.3) how to upgrade to 4.70(ABMJ.4)C0 for example. I can't find 4.60 on the site
  • Zyxel_Adam
    edited June 2022
    Hi @Stoyan89,
    Yes, because the switch GS1920-48v1 is End of Life at 06/30/2019.
    Adam
  • wluna
    wluna Posts: 2  Freshman Member
    Hello, I have some switches GS1920 v1 with version V4.30 (AANZ.0) what is the path to follow for the latest version available and what is the latest version?
  • Zyxel_Melen
    Zyxel_Melen Posts: 2,584  Zyxel Employee
    Hi @wluna,
    Please download from this link:
    GS1920-48 v1 V4.50(AANZ.0)
    Zyxel Melen
