VMG4927-B50A Reset on high bandwidth
This DSL modem configured in dual dsl mode (fed by 2 different DSL connections) to provide me 30Mb down x 4Mb up. However, it randomly will reset - according to the isp this is due to the download speed exceeding the 30Mb bandwidth. I have thoroughly checked all computers behind the modem and all are clean (virus, malware, rootkits, etc.) My background tells me this is a crock but it doesn't stop the resets - which take anywhere from 5 - 10 minutes for the modem to restore internet access - which is intolerable as I work from home on voip via vpn all day (some resets have occurred when all computers have been fully powered OFF). Any ideas, suggestion or help appreciated - isp don't have a clue and keep pointing the finger at me.
Hi Sir, not sure what is "reset" you mentioned, does it means the VMG4927 is keeping reset? However, it seems affecting your usage, I suggest you can contact your ISP again and provide them more detail about the issue which you are encountering, such like your firmware version, configuration, topology, etc..0
Thank you for that - the issue is the ISP doesn't know what to do - the reset is a reboot on the modem - it has to restart both links and then connect back to the internet - 5-10 minute process every time. It shows a bandwith spike (download) of up to 60 Mbs but 30 mps is all the isp is supposed to provide. No ideal how an external bandwith "push" resets the modem or even what causes the spike - it has happened even with all our computers powered off.0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
