Traffic log data are not displayed in VRPT 4.0
Kv3
Kv3 Posts: 10  Freshman Member
First Comment Sixth Anniversary
edited June 2022 in Security
I have Zywall 310.
  After upgrading the firmware from 4.65 to 4.71, Traffic Log data stopped appearing in VRPT 4.0.
Errors listed in the VRPT server log:
2022-06-03 02: 00: 41,106 ERROR (ZldSyslogParser.java:257) - Invalid LOG:
2022-06-03 02: 00: 41,106 ERROR (ZldSyslogParser.java:258) - <142> Jun 3 02:00:41 2022 zywall src = "192.168.1.16:54754" dst = "38.90.226.20:80" msg = "Traffic Log" note = "Traffic Log" user = "unknown" devID = "zzzzzzzzzzzz" cat = "Traffic Log" sourceTranslatedAddress = "yy.yy.yy.yy" sourceTranslatedPort = 54754 duration = 5 sent = 575 rcvd = 594 dir = "LAN1ge3: WAN1ge1" protoID = 6 proto = "http" client_mac = "00:xx:xx:xx:xx:xx"
This is probably due to a change in the syslog logs sent to the VRPT server, Is there any chance that this will be fixed?
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @Kv3
    VRPT server has out of maintenance anymore. We advise replace VRPT server to SecuReporter.
    It could analytic client traffic, bandwidth monitoring, UTM statistics...etc, and the advantage is cloud base service so local syslog server is not required.
  • Kv3
    But this is due to a change in the syslog record sent to the syslog server. In firmware 4.65, the syslog records were fine. Can you please fix this?
  • Zyxel_Stanley
    Hi @Kv3
    New firmware has changed traffic log format to fulfill SecuReporter. Since VRPT has out of service and there is no plan to improve on it any more. Please consider replace to SecuReporter for analyze your network usage.
