GS2210-8HP - Factory Reset
imaohw
imaohw Posts: 124 image  Ally Member
First Comment First Answer Friend Collector Seventh Anniversary
edited August 2022 in Switch
I am repurposing a GS2210-8HP that was take out of service.  I do not have the user name/password.  I want to do a factory reset.
I looked in the manual but it seems I need a "factory default configuration file".  I do not have one available.  Where can I get one or is there an easier way to reset the switch.
  • JasonTsai
    JasonTsai Posts: 104 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Nebula
    Hi @imaohw,
    Welcome to Zyxel community!
    Before you reset your switch to factory defult, you may need the following:
    1.  A PC with terminal emulation software(Ex: Teraterm).
    2. Console cable.
    3. Factory default configuration(.rom).
    You may go to the link Here to download GS2210-8HP Firmware file(.zip) and there is a default configuration file(.rom) in it.
    Then you may follow the user's guide or FAQ Link to reset your switch to factory default.
    Hope it helps.
    Jason
  • Mike_Mike
    Mike_Mike Posts: 5
    Friend Collector
    Same problem here. The rom files are not available anymore.
    I own this brick and would be great to have the rom - since, ridiculously, there is no "reset to factory defaults" procedure available, without serial cable rom upload.
    What could we do to get the rom?
  • Mike_Mike
    Mike_Mike Posts: 5
    Friend Collector
    Please provide the rom file, since there is not available online anymore.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,937 image  Guru Member
    Hi @Mike_Mike,
    May I know which switch model that you need the ROM file?
    Is it GS2210-8HP or other GS2210 model?
    Zyxel Melen
  • Mike_Mike
    Mike_Mike Posts: 5
    Friend Collector
    Hi @Mike_Mike,
    8HP please.
  • Zyxel_Melen
    Hi @Mike_Mike,
    Here is the ROM file of GS2210-8HP.
    If there has any other question, you may feel free to ask.
    Zyxel Melen
  • Rayzzy
    Rayzzy Posts: 3
    Hi Zyxel Melen
    I have the same problem with my GS2200-24 switch can you please supply the configuration files for this model as I cant find them anywhere.
    Thank you.
