Usg Flex 200 Secuextender SSL Vpn
ITS
ITS Posts: 16 image  Freshman Member
I'm using SSL VPN on USG200Flex but is disconnected after 24hours, is there anyway to make it always on? If not is there a script to reconnect automatically?
  • Fred_77
    Fred_77 Posts: 141 image  Ally Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Hi @ITS
    i think it might depend on the user configuration.
    By default re-auth limit is 1440min (24h.).
    You can modify ths value, but i think that "unlimited" is not recommended.
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Never tried that. then in my opinion, Due to security issue. Firewall shouldn't allow the session for a long time.
    For the reconnect automatically, I suppose "AutoIt" may reach the inquiry. maybe is worth a try.
  • Fred_77
    Hi @ITS
  • ITS
    Many thanks
  • Fred_77
    Glad to have been helpful, but consider the security implications of this configuration.
